- NE Nebraska
- EC
It sounds like there will be other equipment located with the pump, so unless the pump room is actually part of the building with the supply panel, there will be multiple supply circuits going to what's probably a separate structure, and that a problem.
Is this pump and the supporting equipment part of the main building or part of a separate shed or pump room? That'll make all the difference.
I agree. One still could legally have what at first appears to be undersized conductors on said feeder all because of allowances for motor starting, but that likely means at least upsizing the conductor some for the additional loads even if the overcurrent device stays at 100.
