rambojoe
- phoenix az
- Wireman
ok. typical large commercial shell. lines come into a 5' by 5' coffin/splice box. and 3 load centers to the right. on the 1 line it is "lined" from the splice box to the loadcenter specifically to the bottom of the busses ( 4/0 parallel,mlo ) and again, mlo out of the top to the middle panel. already piped with line on bottom and nipples to adjacent panel on top.
if it was already wired up with feed to the bottom lugs, would you change it? does it matter? btw its just about 7' of pipe to the coffin...and changing it would mean feeders and taps occupying both sides of the guts. the way the one line was drawn it was easier to "draw" the incoming going to the bottom. what say the masters?
