mshields
- Boston, MA
Between an X-Ray room and it's control room, there is the need to run a DVI cable from the boom to the control room.  The conduit we specified (based on input from the vendor) is 1 1/4 but needs to be at least 2 inch in order to pull those pesky connectors on the end of the cable.
Because the space is finished, they want to avoid opening walls and would like instead to run the cable in the plenum and down the wall in the control room; i.e. a ring and a string type arrangement.
So long as the cable is plenum rated I don't see a problem with it. I am only hesitant because unlike other cables we run in this way, the cable won't be terminated at the wall such as you'd do with an Ethernet cable.
Do I have reason to be concerned?
Thanks,
Mike
Thanks,
Mike
