combo 120 240 receptacles
What is everyone's opinion of these receptacles? Any code issues (other than using an ungrounded conductor color as a grounded color, or white conductor as an ungrounded conductor, if the supplied voltage was changed later)? I have a customer that wants me to install these because they have some 120-240V lights that have 5-15's, but want the option of being able plug in 6-15's later.
wwhitney
Berkeley, CA
Retired
Is it listed? (2011) 406.3(A) requires receptacles to be listed.
A Leviton 5842 or equivalent seems like a better idea: a duplex with one NEMA 5-20 receptacle and one NEMA 6-20 receptacle.
Cheers, Wayne
ActionDave
Chief Moderator
Licensed Electrician
Working on a particular kind of greenhouse are ya?
Thanks, never noticed that.
Cheers, Wayne
I thought about the 5842, but I dont think it helps much. I would still need to feed 240V to the 120V recept. Prob the best solution is to cut off the 5-15 plug and put a 6-15 on.
Yeah man
I didn't know those were still made
I have only seen them one other time, and that was also in a particular type of greenhouse, man.
Sierrasparky
USA
Electrician ,contractor
I don't see how the device pictured would be legit. Who would make such a unsafe device that could be wired 120 or 240?
Id like to be around when someone plugs in a drill or something 120 when device wired 240. Wow that drill runs awfully fast?
Then that magic smoke comes out. :eek:
K8MHZ
Those dual voltage receptacles are usually found in 'grow rooms'. I found some in a lighting controller that had fake UL marks on it. UL was notified and I sent them one of the receptacles. I gave one to the local AHJ and kept 2 for my 'museum'.
They are an obvious NEC violation, listed or not.
Check 406.3 (F) Noninterchangable Types.
Sierrasparky
USA
Yeah man
Now this makes sense!
Hopefully the laws of Natural selection prevail :rotflmao:
user 100
texas
I didn't know those were still made, and never seen one with an EGC pin that I can recall.
The op's weirdo 5-15/20 dual voltage freak show is a foreign conception.
The old t slot 2 wire duplex receptacle is still made by leviton (5000-I) for replacement purposes. As for "why" I have no idea, unless there is somebody with old ungrounded cts and some ancient 120 appliances, lamps, whatever w/ tandem blade plugs that simply wont allow the plug to be swapped out for a parallel type.
FWIU, the implementation of the NEC interchangeability rules posted by K8MHZ as well as Nema streamlining in the '50s and '60s effectively killed that outlet type- it is not (maybe never was?) a nema configuration.
JFletcher
Williamsburg, VA
The leviton 5842 240V half of the receptacle can accept both 15 and 20A plugs, same as the 120V half.
I thought about the 5842, but I dont think it helps much. I would still need to feed 240V to the 120V recept. Prob the best solution is to cut off the 5-15 plug and put a 6-15 on..
If you need a duplex 6-20, see the leviton 5822:
http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=5822-I&section=42416
Pricier* than the receptacle you linked, but it's UL listed and NEC compliant. *By the time you bought the 6-15/20 plugs and wired them, the 5822 receptacle comes out ahead.
