sbutler
 - North Charleston, SC
If you have an 800-amp breaker that can be adjusted down to 600-amp, can you use 600-amp conductors or do you need to use 800-amp?  Where is this allowed in the code?
But there is nothing wrong with installing an 800 amp fused disconnect and using fuse reducers to install 600 amp fuses - and supply 600 amp conductors with that, or installing an 800 amp fused disconnect and installing 700 amp fuses and supplying 700 amp conductors.:blink:
Not sure if I was complaining or not. I guess the :blink: at the end sort of made it seem that way. I don't really know what to think about why the adjustable breaker has different rules then a fuseholder that can accept a variety of fuses and adapters.:roll:
Are you actually complaining the NEC is being practical?
Maybe bring up how the NEC requires a breaker to open all ungrounded conductors at once in many cases but does not require the same of fuses.
I seem to recall the fuse reducers are not listed. That could be an issue.
