I recently got a bit of a lecture for a previous job where an interior load center (FPE) had been replaced with a GE loaded with thin THQP breakers. As I understand it, this is inline for the design specs for the box (12/24), so his comment caught me off guard. Box is a TLM1212CCUG4K
His argument was that the job was improperly done because while ripping out the old panel, a physically larger panel with 1" breakers should have been used.
Now, the downside to that approach - every run of incoming metal conduit would have had to be cut, to relocate the box higher, or half the original circuits spliced, to allow them reach the new breaker locations which would be physically farther away.
Just looking for the preferred solution here. Smaller/tighter box, or tweaking all of the existing runs? This is a common situation in 1960s south florida homes, main panel outside with 1-6 circuits and small inside subpanel with 15-20 circuits.
