The EC who did the initial install is probably long since dead or retired... good luck finding him to sue him.
"Although he clearly suspected an electrical culprit, speculating that one of the appliances in the computer room had overheated,
the fire marshal could not pinpoint the exact cause of the fire."
"Initially, in the first phase of the investigation, the insurance company issued a legal intent to sue the companies that sold all of the appliances present in the computer room before the fire. Pending an investigation of all of the appliances..."
wth? Is it standard procedure for insurance co's to sue on speculation or pending investigation?
"Part 1 — First, an identification was made of each appliance and its wires. Note: Many of the wires and cables were melted/burned in such a fashion that they essentially became one charred cable. It took a great deal of patience to separate these wires into their constituent parts and identify the appliance to which they belonged (Photo 1)."
Photo 1 clearly shows one of those power strips having a 2 prong receptacle. If the receptacle is 2 prong, so is the plug.
The knock-off computer...
"Part 3 — During the third part of the initial investigation, experts theorized what might have caused the fire. However,
none could point to a clear cause."
" This is a good bond,
but the bare wire is NOT in the cable jacket — only a black and white wire run through the cable jacket (i.e., hot and neutral)."
Where the hell else would it be, on the outside? Just a piece of wire shoved in there to look like an AC drain wire? :?:?
Also, that pic shows no substantial fire damage inside or out; the fire didnt originate inside that box. nor anything plugged into its receptacle.
"Why was their no ground wire connected to this grounding-type receptacle
? Did it burn up in the fire?"
Yes, it evaporated in the fire, with no trace left, like David Copperwire, magician, removed it. Or maybe it reached sentience and crawled away. This is the dumbest question I have seen in a long, long time.
Not sure if this article is poorly written, or the incident poorly investigated, or both. In any event, this 9 second video clip sums it up:
https://www.youtube.com/watch?v=Ubw5N8iVDHI
