nietzj
- St. Paul, Minnesota
- Electrician
I have a small project to install a solar powered light fixture in a 16 ft bus shelter. Seems easy enough but since this is the first time I've worked with solar I have a couple questions. The solar panel will be mounted on a pole adjacent to the bus shelter, would I need to add a ground rod and bond the pole and shelter to the ground? Also, I do not have the equipment yet but I assume I will need some sort of disconnect to isolate both the solar power as well as the battery. (hoping the equipment package comes with some instructions)
