flashlight
- NY, NY
- Electrician, semi-retired
So, forty years ago when I was 18, an older guy showed me how to dress AC cable. We call it BX around here.
Some of the old timers were still cutting it with a hacksaw. But he used a roto split tool. Made the cut, nipped the little sharp point of the metal wrapping, put in the red head, wrapped the drain wire neatly back along the grooves in the cable. You guys know the drill.
So thats how I've been doing it for forty years.
Recently another electrician told me he got flagged on inspection (in another state I should add) for nipping off the sharp point.
Says the inspector said the roto split tool was designed to cut the cable and the resulting cut should not be modified.
Due to the fact that I have seen more than a handful of shorts over the years that were caused by that sharp edge of metal, I will continue to do it as I was taught. I know around here many people do it this way, but many do not also.
Just curious how many other sparkies do this.
