Hi,
I’m having trouble finding a relay that I’m looking for to switch between loads in a residential application. I was looking for a 50amp DPDT relay with 120VAC coil and planned to install a set of 3 way switches so the coil could be switched from 2 locations. My question is, would there be a problem with installing a 50amp NO contractor with 120VAC coil and a 50amp NC contractor with 120VAC coil in parallel and switched in the same method? Open to alternative suggestions. TYIA!!
Jason
Jason
