Under budget
- Ny
We have taken on a project to re terminate all wiring in a multi building apartment complex that was wired with aluminum wiring and wirenuts with alumicon purple connectors and copper pigtails to all devices . We are having disagreements amongst the crew as to the existing aluminum wire that is used to ground the metal boxes. Currently the metal boxes have an aluminum conductor from one of the aluminum romex cables wrapped around a machine screw extending to a wirenut with the other cables bare aluminum ground conductor. We are currently replacing this wirenut with an alumicon but leaving the bond connections to the metal box as is under a ground screw with the assumption that ground screws are not required to be listed . Looking forward to feedback from the Mike Holt Community
