homeowner2020
New User
- LA
- Na
I’m trying to install a raypak 6450 pool heat pump and the instructions mention you can use 10 wire with 50 amp breaker if the length is under 97 feet.
i thought 50 amp required 6 wire. It mentions article 440 of NEC, is the heat pump a special case?
