petersonra
- Northern illinois
- Semi-retired engineer
The back stab has a spring on it so thermal expansion just is not an issue.I disagree, I think the NFPA has slowly started to "wake up" realizing just how important an EGC is, and its integrity.
The surface area in a back stab is not the same as in a screw terminal, let alone that the wire can actually move around slightly as the metal expands and contracts breaking the cold weld.
