goldstar
- New Jersey
- Electrical Contractor
With the advent of the new "smart meters", POCO's are no longer sending out a representatives to check for power at a residence. One of my customers (visiting relatives in Michigan) called me and said one of his neighbors noticed a tree down on his property and that the power wires were bent down but not disconnected. He had the neighbor go into his house and noticed the power was not on. He called the POCO and they told him that the power WAS on. He then contacted me to go to the house and check. When I got there I noticed that all 12 AFCI breakers were tripped but the Main 200A breaker was still on. I tried to reset a couple of the AFCI's but they tripped immediately. I then pulled the panel cover off and metered the incoming power. All voltages were correct. Thinking that there must have been some sort of power surge when the tree hit the power line I thought that it may have blown the electronics in each of the AFCI breakers. So, I began temporarily replacing the AFCI's with std. breakers just to get the heat back on. Everything was going great until the smoke alarms went off. I immediately shut the main breaker and went to investigate. When I got to the HO's office I smelled burnt electronics. I then went back to the breaker panel, turned off all the breakers that I had on and then turned on the main. As I turned on one breaker at a time I metered the voltage output of each breaker and noticed that the voltage increased up to between 190 and 240 volts. I realized that it was a bad neutral problem and I shut doen the main breaker. When I went outside to inspect I saw the triplex properly connected at the house. However, looking at the mid-span connection I saw that the neutral had separated.
So, long story, short they say you have to pay for your education - and I did. Thus, lesson learned, "Don't take the POCO's word for it when they tell you that the power is on." Those smart meters are looking at the 240V phase conductors to the house and do not take the neutral into consideration at all. At this point I am not sure if I burnt the electronics or if the AFCI's actually did their job. I'll find out today but my thinking is that I should replace all the AFCI's just as a precaution.
