Yeah. Most conventions say the first number is the primary, but not everyone follows it.What about multiplying by 4?
Said by whom? That is a Vp/Vs ratio of 2.828; how does that make any sense for a "4:1" transformer?40.66 volts is said to be the answer.
"4/1 turns ratio" as stated in the question.
My guess would be that the 105-125V is RMS. So stepping down the maximum from 125V on a 5/1 ratio would be 25V RMS. Then from RMS to the peak voltage would be 25*Sqrt(2) or 35V peak.Answer question asks, "Suppose primary fluctuates between 105 and 125 V on a 5/1 step down transformer. The maximum secondary peak voltage would be about how many volts?" (88, 18, 74, 35)
I would think to just take 1/5th. So I think I'm missing something.
Yeah, I see that, but giving the setup voltage in RMS and expecting the answer in peak without phrasing the question as such is kind of sucky, don't you think?My guess would be that the 105-125V is RMS. So stepping down the maximum from 125V on a 5/1 ratio would be 25V RMS. Then from RMS to the peak voltage would be 25*Sqrt(2) or 35V peak.
Doing the same steps for the original question also gave me the 40.6V.
Yes, but common in classes where they want us to THINK rather than regurgitate results from a single formula. I'm accustomed to being WARNED that questions use different units, and be sure to allow for that. A distance may be in miles, kM, inches, and nautical miles. Temperatures may be in a mix of F, C, K, and R. In the hydraulics classes, you cannot imagine how many pressure units they can come up with.Yeah, I see that, but giving the setup voltage in RMS and expecting the answer in peak without phrasing the question as such is kind of sucky, don't you think?
Well ok, but using RMS V in one part of a problem and peak in another part when there is absolutely no reason or convention is just ridiculous.Yes, but common in classes where they want us to THINK rather than regurgitate results from a single formula. I'm accustomed to being WARNED that questions use different units, and be sure to allow for that. A distance may be in miles, kM, inches, and nautical miles. Temperatures may be in a mix of F, C, K, and R. In the hydraulics classes, you cannot imagine how many pressure units they can come up with.
I think using what is between our ears is important.
In post #1 I don't see any mention of "peak".Okay, I reread the question, I guess I didn't read it very thoroughly the first time and I see they did say "peak". I didn't really notice that at first or assumed they meant peak as in the maximum of the fluctuations.
Post #6.In post #1 I don't see any mention of "peak".
Same video SoCal Chapter IAEI uses to train its members.Hope this helps.
forward to 6:45
Post #6 is a different question.Post #6.
Just pointing out where "peak" appeared.Post #6 is a different question.
And I was just pointing out that the answer to the first question was apparently in peak V where the primary was in RMS V and the question did not ask for it in those terms. I guess one could look at the choices of answers and figure it out, but it's kind of sucky to do that to a student.Just pointing out where "peak" appeared.
