Yes! That's the answer! Conduit would be too big, but uf cable will work. Thoughts on if I should try and protect it from the direct sunlight?Drill straight up through the beams and the 2x4s, and run cable or conduit on top of the wood, so it can't be seen from below. Seal the holes at the top to keep rain out.
UF is sunlight resistant.Thoughts on if I should try and protect it from the direct sunlight?
Does the building code permit that? I have no idea of what the rules would be for drilling vertically through a beam. I would not want to do it without something in the building code that says I can do that.Drill straight up through the beams and the 2x4s, and run cable or conduit on top of the wood, so it can't be seen from below. Seal the holes at the top to keep rain out.
No. It doesn't. Conceal the feeds above and do at most, single drops to the fans. Exposed pipe of any amount would look like crap on woodwork like that.. so less is more. Try drilling or notching in front of the g.c., see what he says. I would still just stick to emt for paintability, just in case. The millwork hardware is flat black so that would look tastfull.Does the building code permit that? I have no idea of what the rules would be for drilling vertically through a beam. I would not want to do it without something in the building code that says I can do that.
Would it even apply to a pergola? This is not really structural.Does the building code permit that?
Its structural when its supporting 800+lbs of lumber dude.Would it even apply to a pergola? This is not really structural.
Those joists are clearly larger than the span or load would require.
He said don't answer that.UF is sunlight resistant.
Dude!Don't answer that, I have it figured out. I'll make the channel a little deeper on top and caulk the top to protect it.
Sorry dude, im trying to be nice without insulting hickcraft...Sorry, Joe, but I don't see a 7/16" hole weakening a 2x10 that much, especially when the neighboring joists and the purlins are certainly capable of holding two of them up.
And . . .
View attachment 2565416![]()
I'm sorry for getting you upset. It wasn't that serious.Sorry dude, im trying to be nice without insulting hickcraft...
After i donate 4 hours of my time helping you make money in private messages and phone calls... You have no authority... Drill it. I do not care. Im just a different electrician. No harm.
I'm not going to drill the supporting beam. I have a gfi outlet to install near the rock in the corner, I'm just going to hide the wires and go up above as quick as possible.
Wirmould 500 and 700 aren't weather resistantView attachment 2565421You could use raceway like this. I/'m sure you can get it in a color the customer likes
sleave the UFwith black painted emt the UF on the straight joist runs with just cable running above the beam drilled 2 inches above the bottom and centered so it wont be visible.I'm not looking forward to this little project. On one hand it is such a nice house and I want the wires to be hidden. But the amount of work to chisel, drill and route a cable seems too much. Emt will work but won't be pleasing to the eye, but maybe that's the price you pay when we come in after the project is finished.
