I have a customer that wishes to insert a fused switch on the secondary of a 480V transformer between the transformer and downstream MCC in order to reduce Arc Flash at downstream location.
Does anyone have experience with a stand-alone switch with this high of a current rating at 480V? From what I see available this would typically be something in a Switchboard type enclosure as opposed to a disconnect type structure? Is it more feasible/economical at this side to just go with an enclosed breaker?
This solution will likely be one that is close coupled to existing transformer secondary due to existing UG conduits.
