mark32
- Currently in NJ
So, my customer has five post lights on their property, and one stopped working. I remove the fixture in question and read 98 volts from the ungrounded conductor to the egc and the grounded conductor. I see that there are leds in the fixture, so I grab a pigtail socket and an incandescent bulb from my stash, and it lights up as I figured it would. (I will mention here that all of these post lights are controlled by a single relay inside the main house) At this point, I remove the incandescent and screw in an led, as I want to run into the house and look at the relay cabinet where this circuit originates, and then poke my head out of a window and see if the led lights up. However, the led now lights up as I screw it into the pigtail?! I remove the pigtail and now I have 120v??!! At the relay cab, it looks like two - two wire circuits are wire nutted together off of the relay. The basement is finished, so I cannot view how these cables are routed. I will note that the cables are romex inside the cabinet, but change over to uf at some point. Anyway, it's getting late, so I put the, now functioning light, back in place and clean up my tools. The owner offered me a burger, which I readily accepted However, as I go to leave, what do you think happened? You got it, the dang light is now off again. At this point, I may or may not bother troubleshooting any further, as the homeowner will soon be getting all new landscaping done in this area. So, I may just have his guy trench about 70' away to the nearest post light, and I'll just refeed the light in that manner. But I am curious what could be taking place here. What could cause this circuit to behave like this?
Happy fourth!!
Happy fourth!!
