There are two 208V 3-phase 3HP motors that I would like to alternate power daily. Let's call them motor 'A' and motor 'B'
For example,
motor 'A' will run on day 1, 3, 5, 7 and so on...
motor 'B' will run on day 2, 4, 6, 8 and so on...
There are multiple methods of doing this but I want an efficient and safe method. These motors will be fed by the same circuit and will be non-coincident load. For this reason I want to ensure the motors do not run at the same time.
I was thinking of using two VFDs (1 for each motor) and interlocking it with an external digital time clock so that it cycles the motors. I am not sure if this is a good method because I am afraid that someone will tamper with the VFD and time clock and cause both of the motors to be running at the same time which is what I'm trying to avoid.
Is using VFDs with external digital time clock a good idea for what I'm trying to do? Let me know if you have any recommendations.
For example,
