My MBPWhat do you mean by your primary?
And if so, how do I achieve that I would assume just running it off of one leg, right?Also, Mr. Larry, I do have a question I’m still learning can I run single phase off of a three phase service
If you have 208Y/120, then you have three single-phase 120v line-to-neutral sources, and/or three single-phase 208v line-to-line sources.And if so, how do I achieve that I would assume just running it off of one leg, right?
MDP? (Main distribution panel)My MBP
That is not a term used in my area or one that I have heard of.My MBP
Yes sorry typoMDP? (Main distribution panel)
MDP sorry typoMBP=main breaker panel?
This is a real situation and for my education!I think we need more information. Is this a real situation or something for your education?
I am an apprentice and I am just doing my research too understand and make sure the job is done properly! I appreciate your help very muchIf you have 208Y/120, then you have three single-phase 120v line-to-neutral sources, and/or three single-phase 208v line-to-line sources.
This is pretty basic stuff.
Thank you for telling us where you are coming from. Do you have supervision on site?I am an apprentice and I am just doing my research too understand and make sure the job is done properly! I appreciate your help very much
Yes and No my supervisor is expecting me too do the research and too make sure I do the job properlyThank you for telling us where you are coming from. Do you have supervision on site?
It is common to take a single phase feeder, which would consist of two hots and the neutral, off a three phase system.And if so, how do I achieve that I would assume just running it off of one leg, right?
Yes. It depends on the electrical needs of the devices you're looking to supply power to.It is common to take a single phase feeder, which would consist of two hots and the neutral, off a three phase system.
