Would like to know how that works out?Is it justifiable to charge for a full day in that case?
That system might be received better than 2-hr minimum, and beat asking for gas money when the solution didn't require any work?When I get a service call, I have a "Diagnostic" charge. When I discover the problem I will give them an estimate for the complete repair. If they accept it, I will credit the diagnostic fee.
That never happensWhat happens when your diagnosis & parts fail to fix it?
Nice way to treat remote clients, rather than over pricing the rate.four minimums when over an hour away. And then I just bill hourly at regular rate.
James, just curious, is this or has this been your practice? As a sole proprietor, still in the growing stage, would settle with $100,000. And that’s including an owner salary and tools on.I think if you're going the route of time + materials, then it ought to stand. It's not time + materials + wasted time.
I think a T & M rate should factor in that wasted time. I believe out of a 2,080 hour work year, a service electrician will only have about 1,200 hours of billable time.
Just suppose you want to make $200,000 per year. That's $96.00 per hour on a full 2,080 hr year.
But in order to make that same $200,000 per year on only 1,200 billable hours, the rate needs to be $166.00
$166.00 x 6 hours is $996.00
I think most electricians would be okay with that
That has not been my ongoing experience, but when I was incorporating service work into my routine, I had a rate that was substantially higher than my bid rate as a subcontractor.James, just curious, is this or has this been your practice? As a sole proprietor, still in the growing stage, would settle with $100,000. And that’s including an owner salary and tools on.
So far all I have done have been right at the panel. Inside or outside. Mostly outside.Last generator inlet I did was 2200. With about 60 feet of 3/4 pvc
That should be a 500 min job. People will ask for a free estimate and you say 350ish and they'll keep shopping around. You say 500 min then you can have more buffer but even at 500 min say that's only under the most ideal circumstances.The last one I did I think I charged $375
But it was a whole house remodel and I was swapping out the panel already. This one was added onto the panel with an offset nipple and it was supplied by the customer. I did have to buy the interlock. I had less than an hour in the whole thing and I was already there.
I had another one I did for $450 and the homeowner supplied the inlet. I was already swapping out that panel as well, so I was already there. I think it was about 12 ft from the panel with a piece of Romex to the outside. Basically like air conditioner disconnect.
I say just price it with the number you know is right, let the chips fall where they may. Make sure you're making money on every bid, and don't worry too much about how many people say yes or no. You'll get enough to say yes
