drcampbell
- The Motor City, Michigan USA
- Registered Professional Engineer
Then again, from the sounds of it, so might have proper overcurrent protection.
No. Or, that's not in the video.I didn't wantch the entire thing. Did officials or the author of the video claim afci would have helped?
Loose connections. The current flow can be very low but enough heat is generated that the connections can actually glow red. I've seen it more than once and the resulting damage is obvious. Anyplace connections are improperly made.I don't get this term 'glowing arc' but okay.
Right but that's not an arc. (And no AFCI product has ever made a claim to detect it, nor could one.)Loose connections. The current flow can be very low but enough heat is generated that the connections can actually glow red. I've seen it more than once and the resulting damage is obvious. Anyplace connections are improperly made.
Don't see AFCI required for boats, by US Title 33 CFR Sections 183.401 - 183.460, much less in 1981, when Conception was built.AFCI's might have prevented 34 deaths
Enforcing labor qualifications on any industry, much less local language skills, to communicate with product technical support, becomes a political issue.Call it whatever you want. The point is there is no evidence that AFCIs do anything to prevent fires.
A arc can glow... it happens through non-conductive material. Everyone here knows how a lightbulb works. Im with calling it a "glow arc" is folly but since you are for wiki and the such- look at lab created arcs on video...You guys who want to call glowing connections 'arcs', do you call an incandescent lightbulb an arc too?
To me an arc happens through the air, across a gap between conductors (however temporary and fleeting the gap is). Wikipedia and websters agree, although I'll grant Oxford is vague. To me an arc generally looks quite different from a hot connection, it does not resemble black body radiation; the glow you guys describe as an arc is from the temperature of the metal, looks the same as if you heated it with a non-electric method.
But I guess if you all want to use the word 'arc' less precisely I can't stop you.
I dont know, seems all views on the subject are interesting seeing that electrical dangers are sorta our doctrine here...
That was a tragic accident.
The report can be found here:
Who knows the reason, but "video unavailable" is a statement of it's own...Then again, from the sounds of it, so might have proper overcurrent protection.
