I have a customer with panel mounted in an exterior wall. It's a 4" wall and I'd like to lower the panel because the bottom is probably at least 6 ft high. It has an LB outside and stubs into the back of the panel. Is there a short radius 90 that would be able to turn inside the wall and go down into the top of the panel if I moved it down? It would likely resemble a plumbing elbow but I don't think I've ever seen anything like that for electrical use. Any suggestions other than pulling the existing LB and lowering it so he doesn't have to patch a hole in the siding? Thanks.
