NickJoh
- Columbia, SC
- Retired Engineer
In trouble shooting the breaker tripping of a 2 HP 230 volt single phase jet pump motor on our irrigation pump I discovered the "run" capacitor is "open". Is that likely to mean a winding shorted and destroyed the run capacitor? Or could the open run capacitor cause the breaker to trip?
A little more info: When the relay applies the 230 volts to the motor the sound from the motor is a buzzing sound for a second or two before the breaker trips. It does not sound as if the motor is trying to spin at all even though the start capacitor checks out fine.
While I am an engineer I have very little experience in this area and don't want to replace the run capacitor if it makes no sense.
My other problem (but only if you tell me replacing the run capacitor is worth a shot) is this run capacitor is so old and discolored I can't tell what its value was. I realize they should be the value originally specified but if I can 't find that value is there a range that "should" work for a 2 HP 230 volt single phase motor?
