ChefTurnedSparky
- Columbus, Ohio
- Electrician
Two large AHU units are being replaced, moving from a single fan unit to quad fans. Two VFDs will control two each of the four fans, each fan having a disconnect at the unit. VFDs are being provided by HVAC contractor, I don’t have any specs yet. I am assuming that the two fans controlled by a single VFD will be controlled identically? I’ve never seen it set up this way. If that is the case, would it be acceptable to run both feeders from the VFD in the same pipe and then split before the disconnects at the fans? I assume if they are controlled seperately then they should be run separate as well, due to the frequency differences?
