Seven-Delta-FortyOne
Goin’ Down In Flames........
- Humboldt
- EC and GC
…..At least in my area.
Surface mounted exterior panel, someone wants to add a circuit, and they run a short piece of pvc conduit down the outside of the house with romex inside, attached to the siding, and then LB into the crawl space.
See it all the time. But it should transition from THWN-2 to romex, either in a box or in the LB if it’s listed for that.
You guys see this a lot?
