Mark Ash Fork Electric
- Northern Arizona
- Electrician
I found 583 volts at the ground rod the hard way as a AC unit started up. Voltage creeping down gradually after breaking rotor.
I have isolated the problem to the AC unit.
It is a 240 vac unit without a neutral.
Conductors and connections are in good condition.
The blower motor recently installed.
I can not think of anything but a short within the compressor.
Which direction would you go?
