photonboy
- Berkeley, CA, USA
- Ex roof monkey, current desk jockey
Unfortunately this is all I have to work with. Tried googling around but can't find any other images or descriptions of these.Do you have a photo of the label on the disconnect door?
That's a single pole switch.I have never seen one of these before. I can't really see how the internals connect, this is being represented as a 60A 2p.
Question is are both lines being fused here?
Thanks.
Oh, OK; it's a fuse blowing switch.Looks to me that the black wire feeds the bottom of the fuse. That's a setup I've never seen for sure.
I don't see the jumpers you see.This is what I see.
I can't make out what is behind the clear plastic. Appears to me to be a jumper. If it isn't a jumper, nothing happens when the device is toggled so that's why I was assuming. I can't tell if what I'm seeing is mounted to the teminals or if that is something in the back mounted to the can.I don't see the jumpers you see.
I couldn't tell either but was a little suspicious that it may be something similar as suggested and all three poles along with the fuse are all in series somehow. Why makes little sense other than maybe for higher voltage and/or DC applications. Though the switch still isn't listed for any more than it is marked.I can't make out what is behind the clear plastic. Appears to me to be a jumper. If it isn't a jumper, nothing happens when the device is toggled so that's why I was assuming. I can't tell if what I'm seeing is mounted to the teminals or if that is something in the back mounted to the can.
Actually, multiple poles in series can increase current-interrupting capability and contact life,Yes, it looks like the circuit is routed through the blades multiple times to increase voltage rating.
It used to be done as a matter of course in using primarily AC rated discos to interrupt high voltage high current DC circuits because of DC's propensity to support an arc.Actually, multiple poles in series can increase current-interrupting capability and contact life,
