pipe_bender
 - Boston
 - Electrician
Stupid question does code require all the pins on a receptacle to be used as marked ?
And if so where in the code is this required?
Assuming I leave a nice printed label on the receptacle stating the voltage would these be a violation:
A pin and sleeve outlet and cord thats 480/3 ph, used it for 480 single phase load (one phase missing)?
A 5 wire 3-phase NEMA L21-30 receptacle to a 208 mixer motor that has no neutral can I leave the neutral pin empty?
A 120/240 NEMA 14-50 with the neutral pin omitted for a 240V EV load.
Thanks all
Thanks all
