MagneticVane
 - Rochester, NY
 - Electrical contractor/electrician
Hello guys, I am having issue with my business partner, customer and other contractor over something  that I can see as a clear violation on the code requirements, and I happened to understood this code perfectly clear, EGC and Neutral shall not date with each other after either the main disconnect or the main panel throughout the building wiring. First of all, few weeks ago a general contractor that got nothing to do with us, installed a single wall unit combo of Microwave oven and convection oven made by LG, they said not to touch anything on that unit, otherwise they will void the warranty. I am not going to touch on that part which is fine by me. My real issue is that I am upgrading a panel, from Challenger to Square D, and note that the cable for the oven combo unit was 3 wire, I am aware that the microwave oven  run normally at 120v, so therefore neutral is required, and I brought up this issue with my partner and he went into defense mode and telling me not to worry, damn it, thanks Mike Holt for the education on EGC 101, I can't just shut up and walk away thinking of what could happen in the future, not going get into that detail as you know what I am talking about. I had to look up on LG website for this model. I was indeed surprised to note that the manufacturer clearly state that 4 wire is required, also realizes that the cable used might be a size too small, got my partner challenge me even more, said that I am not responsible for anything if something happens. I am not sure whether I should shut up and let it go because the permit I pulled got nothing to do with oven combo installation, just the panel replacement and I have no idea if they (Other contractor) obtain a permit for the oven/microwave installation and if so, how come they passed an inspection at their end? My partner suggested we talk with the inspector and go from there, I am curious what are your thoughts, feedback?
