In this day and age, I understand your problem. But what @WD-40 posted is correct. You're in a building that was not designed for any air conditioning. Built in 1931 Window ACs went even invented.I plan to keep the focus on safety not upgrades. It's NY and 100 degree weather. Am I unreasonable that I choose to run two ACs (one in the BR and the other living room)? I didn't configure the circuits to have one 15A powering two ACs and a fridge. There is only one light that works clearly when this happens and it's at the other end of the apt. It appears that the room has it's own circuit and the rest of apt is on the other 15A
I think this is a cover yourself comment. I certainly wouldn't guarantee my recommendations will provide a perfect solution 100% of the time.Well, 50/50 is better than nothing but I would have thought they could give better odds if they know the issue is between the floors.
Not asking for a 100% because the building has issues from the POCO on in. No one can fix that. But to say we can only give a 50/50 chance from there on up to the 3rd floor, nope. They aren't trying. Then again, I don't know what you get for $6000 in NYC. That may be a couple #12s.I think this is a cover yourself comment. I certainly wouldn't guarantee my recommendations will provide a perfect solution 100% of the time.
You as the electrician can say your actions solve the problem 99% of the time, but the owner and tenant are only concerned with their specific issue.But to say we can only give a 50/50 chance from there on up to the 3rd floor, nope.
yes, he said it was. I am going to keep following the issue closely and may ask for a housing inspector to come. The law in NYC is exceptionally broad. The law requires that your apartment be “adequate to supply electrical current to the required fixtures and appliances” (NYC HMC §27–2026).
If it gets worse, I'll try and escalate. I know I'm not the only one having this problem in NYC but all modern apartments have more than one breaker for ACs and appliances. You were right, this place was built in 1931 for hotplate and a clothes iron
It certainly wasn't when built.
I don’t believe an AC is a “required appliance”
First Window Air Conditioner (1932)
The Thorne, this is considered the very first window air conditioner ever. This picture is from the June 15, 1932 issue of Electric Refrigeration News. (Thanks to Andy Kluck for this picture.) A small quantity of these were made but this unit was never mass-produced. It was designed and tested in the spring of 1931 by Ward Thorne of Chicago and advertised for sale in 1932 by Thorne Motor Corporation.
@Joethemechanic Thanks for that! Imagine what that would be worth if any survived!
My first job out of school I worked for an oil company who also did refrigeration and air-conditioning. They were a York distributor back in the day and sold everything from ice machines, roof top units , window units etc. I started in 73' and we had a few customers with York window units from the 50s' still running. Back then York (like many others) made quality stuff that lasted.
Not like todays Chinese junk.
It may not last as long, but will be seriously more efficient. You may be able to hear yourself think as well.My 1980ish gibsons have been cooling this office addition they put on the building in 1980. One is still working. One just went bad with some kind of ground fault in the compressor. I was going to fix it but I had to pull it out of the wall to get the cover off and it weighs so much. Not to mention the bottom of the pocket it slides in is 8 feet off the floor. I had to use a tripod to get it down. Good thing I got that knot tying badge in the Boy Scouts in 1970ish. It's only a 10,000 BTU unit and it had to have weighed 200 pounds. The replacements are like 60 or 70 pounds. I just didn't want to have to get that 200 pound monstrosity back up there so I just ordered a new one
Yeah I'm 64 and have a torn Achilles tendon that makes ladder climbing a challenge. Plus getting hurt when you are older hurts a lot more and seems to last a lot longer@Joethemechanic
Yes I just replaced one. Mine is a 12000 btu in my condo . Bottom of the unit is 65"aff. I used to pull it out of there myself it's about 80 lbs and I used to do it with no issue. I just turned 72 and I didn't want to try it myself anymore had to get help. getting old sucks.
It does give us something to talk about with the guy that we can't remember who the heck is.Yeah I'm 64 and have a torn Achilles tendon that makes ladder climbing a challenge. Plus getting hurt when you are older hurts a lot more and seems to last a lot longer
