former inspector
- Modesto, Ca
- Retired Building Inspector
Hi everyone. I was on another thread that was closed for comment. It was a post that a guy said that his inspector wanted the back side of a plastic box protected. I would like to hear from folks regarding this and their opinions on the required protection. CEC 300.4 and NEC 300.4. (NFPA 70). When you look at the code requirements, it is clear as day that protection is required when the conductor is within 1 1/4" from framing member's edge. This is a direct violation of the codes if the wire is closer than the 1 1/4" when it enters the back of the box. The code gives you the requirements that "Shall" be required and the "Exemptions". The plastic box is not an exemption, and does not protect the wiring inside, that is very close. Thus, protection must be provided to a plastic box and wiring inside closer then 1 1/4" to framing member's edge. Call it what is, it just got missed or ignored. There are actually two directions of space that is required at 1 1/4". The plastic box does not meet the required exemptions no matter of all our opinions. It has been missed and never called and should and will be in the future. The verbiage requires it, but you may not find it in any handbook for depictions. I have talked to many code professionals here in California who have stated it is required. What I find on here is that everyone has their own opinions, which is great and needed, but fail too accurately understand this section. My homes I build get this protection now. There is a product made to address this section, and they are from, Metal Products Company in Springfield Oregon, that I use and order this product from. It's called the EBT 1, and it's a patented part just for this location. It works great and is so easy. It's on their website. for some unknown reason people fail to see this requirement or don't want to. Thanks everyone.
