Eddie702
Licensed Electrician
- Western Massachusetts
- Electrician
I am in the middle of my 2026 Code Class 7 1/2 Hours today and 7 1/2 tomorrow.
1. Electric water heaters are considered a continuous load
2. 10 amp circuits, apparently not all mfg. have 10-amp AFCI breakers yet. They think it will be a while.
3. New GFCI breakers coming out for stoves (Type HF) to combat stove tripping problems. Just hitting the market. MA has not adopted the 2026 but likely will in the next month or two.
4. MA has an exception where you don't have to put a GFCI on a stove. In fact if you have equipment tripping a GFCI you have to fill out a form and submit it to the state to get relief. They claim stoves are the majority of tripping problems
5.They seem to be uptight ( the code) about reconditioned/remanufactured equipment can't use it in some cases depending on what it is
6. a lot of talk about listed staples for NM, AC cable and listed wire ty and listed wire ty supports.
More after tomorrow. Bored to death. Had several speakers (about 5) that are on the code making panels and also went over the proposed MA amendments.
