Mustwin351
- Texas
Here is the situation. I maintain a camp on a large military installation. There is one service for my camp that feeds 6 large transformers that feed buildings and areas throughout. One of these transformers feeds a large panel that then feeds two smaller 200A panels that fed laundry tents. Now these tents have gone a way and they've brought in a single wide building with a 100amp panel. This building sits about 10 feet from the dual 200A panels. I wanted to run power to this new building but was unsure on a couple of things. I know running a single branch circuit or multiwire circuit is no problem but unfortunately the 100 amp panel in the new building will not support my load which will contain 3 dryers and 3 washers. I'm guessing it's not legal to run more than one branch circuit (one for the 100amp panel and then one for a new panel I will set on the outside of the building to supply the washers and dryers.)?
I'm sure this is about as clear as mud but a little discussion may help me.
Thanks.
Thanks.
