mstrlucky74
- NJ
Specs says RHH/RHW-2/USE-2 Low smoke zero halogen. Can you have both? Aren't they both insulations?
I see 3... so are referring to any 2 in particular?Specs says RHH/RHW-2/USE-2 Low smoke zero halogen. Can you have both? Aren't they both insulations?
For example can you have a USE-2 wire with LSZH also? These are not BOTH insulation types? I would say not because I have seen this wire before.
Maybe LSZH is the jacket and not the insulation
LSZH ( or LSOH or LS0H or LSFH or OHLS) is an additional classification for the jacket/insulation... but it has nothing to do with conductor insulating properties, at least not directly. Somewhat similar to conductor types that are additionally labeled sunlight resistant.For example can you have a USE-2 wire with LSZH also? These are not BOTH insulation types? I would say not because I have seen this wire before.
