7 Deer
New member
- Dixon, Il, usa
I am installing A 50 kva older transformer. It does not have a x0 connection. It is a separately derived system that needs to have the ground and neutral bonded together. The neutral will be at the x2x3 connection. So I plan on bonding at this terminal. I am just checking to see if anyone has a different solution. Thank you for any input.
