You also need the terminal voltage of the motor.
If you allow say a 5% drop out to the motor, you need to look at the motor characteristics with a terminal voltage of 95%. If the motor is rated 115V on 120V system you just used your 5% margin.
The motor characteristics need to be looked at for starting. Just because you think it will run, doesn't guarantee it's going to start.
