100 amp service large enough for a heat pump?
Stevenfyeager
United States, Indiana
electrical contractor
For a 1200 sq ft new house, I would always install a 200 amp service if they are using a heat pump for heating. But when I do calculations for existing small houses like this, it seems that 100 amps is borderline, but might work. Asuming all electric. What do you do?
Thank you
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
The heat pump is not the issue so much as the heat strips. Without other info it is impossible to know whether a 100 amp service will work. There is also a 125 amp service that may suit your fancy
