User Tag List
Results 1 to 2 of 2
Thread: Reefer vans, 3-ph 480-v, avail power 3-ph 208
  1. #1
    Join Date
    Aug 2011
    Fairbanks Alaska USA
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Would like to install a couple of 40-ft reefer vans at a retail/warehouse location. All units we find are 480-volt 3-phase. Building has 208 3-phase. Any suggestions. Are transformers effecient? Considering just replacing the freezer units themselves with those that will run on 208 but rather expensive. the 480-volt appear to have become the standard of the industry. We also may want to install more units later on. Any ideas?
    Thanks, Mark
  2. #2
    Join Date
    Apr 2004
    Mission Viejo, CA
    Posts
    5,625
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
    If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
    "Bob"
    Robert B. Alexander, P.E.
    Answers based on 2017 NEC unless otherwise noted.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
