I’m working with a franklin controls IMS3R-RV-S4/J-G200 running 75Hp 3 phase motor [MENTION=63279]480[/MENTION]V. my problem is after start up, could be 5 minutes and has gone as long as 7 hrs before it starts reading a random amperage spike 125, 220, 300, with just over a 1000A being the highest I’ve seen on the readout before it shuts down with an obvious overload fault code. I’ve monitored incoming voltage as well as voltage leaving the mag all of which seems to be fine. I haven’t caught these same readings with my amp meters. I sent the motor in to a local motor shop for analysis and they tell me there are no issues with the motor. I have also contacted tech support from manufacturer of soft start for any helpful advice, again coming up with no solid answers. Any thoughts on the matter would be appreciated!
