User Tag List
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 36
Thread: 51.4 volts on 3-way receptacle
  1. #1
    Join Date
    Jan 2011
    Pennsylvania, USA
    Posts
    51
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Electrical engineer here - question on my own home for a change. Newer home, with a 3-way switch-controlled receptacle in one room. Over Christmas my wife unplugged the lamp that was being used on the recept, and plugged in some LED lights. We noticed that when the switch was off, they still lit (dimly). Finally got around to metering the receptacle today: 123 volts when the switch is on (OK). However, still 51.4 volts when the switch is off. Standard outlet tester indicates (red light off / 2 yellow lights on) that the outlet is ok from that standpoint. Thoughts on what to do / where to start 'troubleshooting'? I'm hoping this isn't a wiring issue. I'm a handyman also, but typically prefer projects by choice! Thanks in advance.
  2. #2
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,718
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    160126-1848 EST
    jonathankpa:
    You are probably seeing what might be expected. Since you are an electrical engineer I suggest you devise some experiments to help you reason what is a possible cause of your observation.
  3. #3
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,225
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Do you by any chance have a lighted switch in the mix? Or a three way dimmer set? Or are they just plain snap switches?
  4. #4
    Join Date
    Jan 2011
    Pennsylvania, USA
    Posts
    51
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoldDigger View Post
    Thanks, GoldDigger. No lighted switch. No dimmer. Indeed, just plain snap switches.
  5. #5
    Join Date
    Jan 2011
    Pennsylvania, USA
    Posts
    51
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gar View Post
    160126-1848 EST
    jonathankpa:
    I assume you mean "expected in case of a problem with (whatever)", rather than expected/normal - ? I need to sit down and diagram possibilities, but hoping some of the expertise here will have ideas...
  6. #6
    Join Date
    Dec 2012
    Posts
    20,225
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Nope. Expected normal in some cases.
    Ask yourself where limited current could be coming from.
    Hint: do not limit yourself to resistive sources.
  7. #7
    Join Date
    Feb 2006
    Jersey
    Posts
    2,468
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I seem to recall some switches in the past that worked yet didn't work yet worked ??
    Replacing switches solved the problem
    For grins and five bucks. Replace both switches.
    " I'm at a crucial part of my painting "...........Monika Danneman
  8. #8
    Join Date
    Feb 2006
    Jersey
    Posts
    2,468
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oh. And don't back stab and check the recept for back stab.
  9. #9
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,718
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    160126-2220 EST
    jonathankpa:
    Think Thevenin's equivalent circuit and source impedance. What is the distribution of wires in a cable?
  10. #10
    Join Date
    Apr 2009
    Olathe, Kansas 338 mi SE of Wingedhorses
    Posts
    2,738
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't know if it is Germane to the problem but, Is the whole receptacle switched or just one half of the receptacle ?
    Electricity is Color Blind
    Leave the shirt pocket rules in your pocket.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
