User Tag List
Page 9 of 9 FirstFirst ... 7 8 9
Results 81 to 90 of 90
Thread: Is a parking canopy a "building"
  1. #81
    Join Date
    Nov 2015
    CA, USA
    Posts
    790
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by wwhitney View Post
    Bad logic, as previously discussed. Under the 2014 NEC definitions, a building is part of a structure, and every structure is one or more buildings.
    Cheers, Wayne
    Nope. Every building is a structure. Every structure is not a building.
    Building. A structure that stands alone or that is cut off from adjoining structures by fire walls with all openings therein protected by approved fire doors.
    Structure. That which is built or constructed.
    The definition for building states it is a structure. The definition for structure does not state that it is one or more buildings.
  2. #82
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,349
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    True. A structure that does not stand alone might not be a building, but just what would be an example of such a structure? It is, however, correct that a structure could also be more than one building.
  3. #83
    Join Date
    Apr 2007
    Berkeley, CA
    Posts
    1,904
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I see a possible source of confusion here.
    Say you have a house (a structure) and you build an attached carport. It will require some fire rating of the adjoining house wall, but I don't think the fire rating necessarily reaches the standard of "fire walls with all openings therein protected by approved fire doors". In any event, for the purposes of discussion, say it doesn't.
    Now, do you have one structure or two? I say you have one structure, you just made it larger. It was one building before the carport, and it is one building after the carport. From this point of view, every structure "stands alone", in that it eventually stops and is surrounded by non-structure. So every structure contains at least one building.
    Alternately you could say that the house and carport are two structures. That would mean that the carport is a structure that doesn't stand alone and doesn't meet the NEC definition of building. The problem with this idea is that it also implies that the house is no longer a building, which is nonsensical.
    The conclusion is that under the NEC definitions, you can't have a structure without having at least one building.
    Cheers, Wayne
  4. #84
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoldDigger View Post
    ... A structure that does not stand alone might not be a building, but just what would be an example of such a structure? ...
    A structure within a structure that is not a building. The surrounding or complete structure is not a building, and the structure therein is also not a building.
    Here's a building within a structure that is not a building...
    I will have achieved my life's goal if I die with a smile on my face.
  5. #85
    Join Date
    Apr 2007
    Berkeley, CA
    Posts
    1,904
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok, so to avoid RSS on a ground mount PV system, just build a geodesic dome around it.
    Got it. :-)
    Cheers, Wayne
  6. #86
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Got it. :-)
    Cheers, Wayne
  7. #87
    Join Date
    Nov 2015
    CA, USA
    Posts
    790
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Smart $ View Post
    Now that's a Venn diagram.
  8. #88
    Join Date
    Nov 2015
    CA, USA
    Posts
    790
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It could be if the buildings were connected together by structures.
  9. #89
    Join Date
    Dec 2012
    Posts
    20,349
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by pv_n00b View Post
    You mean if the buildings were connected together by other buildings?
  10. #90
    Join Date
    Nov 2015
    CA, USA
    Posts
    790
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No, actually by other structures in general but they could be connected by a building since a building is a structure. The buildings could also be connected by a structure that is not a building and then it could be considered one large structure. I am not sure how a group of separate, unconnected buildings could be considered one structure though.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
