User Tag List
Results 1 to 4 of 4
Thread: Conductors in conduit - wet location?
  1. #1
    Join Date
    Sep 2004
    Temecula, CA
    Posts
    215
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Based on 2011 NEC
    (I am assuming it is still in '14 and '17, just 2011 is the code cycle in use at the time of this issue.)
    Having a senior moment, could use some help.
    I know at some point I have read somewhere in Mike's arsenal - (books, this forum, newsletter, etc.) that conductors, even though located inside a conduit, are required to be suitable for wet location if the conduit is installed outdoors or underground. I am searching for the code section with no luck.
    Been through the standard stuff - 310.10, table 310.104(A), Articles 320 to 362 for specific types of conduits, but I am not having any luck.
    When a conduit is located outdoors or underground, are the conductors inside required to be listed for a wet location?
    I believe they are, and I believe I found (with Mike's help) that requirement previously in the code. But I have slept since then, so all memory bets are off.
    Any help would be greatly appreciated.
    Thanks -
    " One of my reasons for success: I learned to feel comfortable being uncomfortable." -- Cal Ripken, Jr.
  2. #2
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,032
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    300.9 Raceways in Wet Locations Abovegrade. Where raceways are installed in wet locations abovegrade, the interior of these raceways shall be considered to be a wet location. Insulated conductors and cables installed in raceways in wet locations abovegrade shall comply with 310.1 O(C).
  3. #3
    Join Date
    Sep 2004
    Temecula, CA
    Posts
    215
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by iwire View Post
    Thank you, Iwire, I appreciate your help. And the fast response. I do appreciate it. God Bless.
  4. #4
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,032
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by inspector23 View Post
    You are welcome and have a great day.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
