User Tag List
Results 1 to 4 of 4
Thread: 480V in Residential
  1. #1
    Join Date
    May 2010
    NJ
    Posts
    42
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    480V in Residential
    Hi,
    I have a situation where I need to do a long run for a PV system in residential. I was thinking of going with a transformer (and yes I know it will be expensive but way less then other options) from 120 to 480 then bringing it back down to 120 for voltage drop and I need to use an existing pipe that is only 2"
    My question is......Are there any codes that prohibit 480 in a residence (besides the 277V Lighting code)?
    “He has no enemies, but is intensely disliked by his friends.”
  2. #2
    Join Date
    Jun 2015
    texas
    Posts
    1,698
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Castrovinci View Post
    In your situation, No. There are branch ckt limitations in 210.6, but those are irrelevant here.
    IIRC the limit in your case is 600v- see 690.7.
  3. #3
    Join Date
    Jun 2003
    Posts
    11,398
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What is the distance and the load you will have? The 2” will be limiting.
    600v @ 100 amp @ 600 ft will give a VD of about 22 with 2/0 al wire. That could be a pretty tough pull even without 90s.
    The EG will need to be increased in size.
    Tom
    TBLO
  4. #4
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,906
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Hi,
    Why not just bring the dc strings back, they are already up around 480 anyway, and skip the tranny?. Better yet, use a fronius primo inverter that does 1kv strings. With 1 kv, you just couldn't have the inverter inside the house.
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
