User Tag List
Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 48 of 48
Thread: Semantics of "Area Classification" and who should determined Areas
  1. #41
    Join Date
    Jun 2004
    Posts
    91
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    HAZLOC
    Quote Originally Posted by rbalex View Post
    I have served on three national level "HazLoc" Technical Committees. Almost without exception, the membership was all "electrical", the lone exception was the API Subcommittee on Electrical Equipment (API RP 500 and 505) where a few members were "mechanical" representing some motor interests.
    I have said before, "Hazardous location classification is not rocket science".It is definitely a collaborative activity, but all that is actually needed is the process flow diagrams, flow stream material balances and an accurate plot plan. You often don't even need that much for installations within the scopes of Articles 511 to 516.
    rbalex, "Curious..." infancy by OP was the beginning of this thread. I want to ask a question rather than adhere to a statement originally posted without proper syntactically corrected text, that is a question not a statement in the beginning OP addition to this Hazardous Portion.
    In relation to "...(API RP 500 and 505)..." and MAOP of equipment essentially utility gas compression, new and/or rebuilt by qualified OEM technicians, how does the API view acceptance of their published diagram's when over pressurization boundaries both process and venting of maximum allowable operating target limits and the final rule placed in federal register entry for a change when reviewed on 1 year cycles "Incoroporation By Reference" as compared compared to 3 year cycles by industry committees ? Or better still how does your committee ascertain your published approved wording and reference diagrams? (other than marking syntax by (new, revised, of deleted) marking as explained in the beginning of the publication?)
    Thank You So Much. I think that was 3 questions, please accept any grammatical challenges.
  2. #42
    Join Date
    May 2010
    Washington
    Posts
    95
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There is a 2014 IEEE PCIC paper "Electrical Hazardous Area Classification Design as a Basis for Safer Operations" that discusses the increased role that the hazardous area classification drawings can play beyond just for electrical installations. I would say that this paper is more of an acknowledgment to how some in the industry are already using their hazardous area classification documents as opposed to it being a brand new idea.
    In that regard, the methodology and standards may still belong to the "Electrical" folks but if the API and the industry come to formally identify these documents as the basis for their siting and safe work, we will likely start seeing other disciplines getting engaged.
  3. #43
    Join Date
    Jun 2004
    Posts
    91
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by nec_addicted View Post
    The question of MAOP quoted above from a CFR standpoint pasted in from resources below, is an example in timeline I was hoping to obtain, from a knowledgeable source related to NFPA committee eccentric past relevance to understand how reference exhibits appear in each update to NFPA 70.
    Determining Class Location
    Building Count, Clustering,
    Boundaries
    MAOP review
    • "In addition, 49 CFR 192.619(a)(3) allows an operator
    to establish an MAOP based upon the 5‐year window
    for older systems prior to July 1, 1970. Once that has
    been established and documented and a class
    location study is performed resulting in a class
    location change from what it was on July 1, 1970,
    does the operator have to incorporate a class
    location factor for revision of the MAOP established
    by the 5‐year window? Our contention is that the
    operator does not."
    MAOP review
    • If a class location study identifies a pipeline segment
    with a hoop stress corresponding to an established
    MAOP that is not commensurate with the present
    class location, the operator must confirm or revise
    the MAOP of the pipeline segment using one of the
    three methods in § 192.611(a). Operators must use
    all the applicable class location factors wherever called for in each of these methods.
    Here is where an Architect would use building codes to establish safe areas for blowout panels when over pressurization was a subject of an upgrade. However this one answer hinges on a 5 year cycle.
    It turns out my understanding is NFPA has a remedy to view any of their proposed section in the form of public industry may "view only" interested parties request for exact code and article or in my case exhibits that are changes to hazardous area classification boundaries. The release of Tentative Interim Agreements (TIA's) library during the approval cycle location is still unclear to this caller.
    That much information obtained today in a chat log with NFPA. When the caller asked about NFPA 70 of course the 3 year revision recently out had zero proposals from industry at this time.
    That is sort of the long and short of my curious question's?
    Optionally my centrist API 500 and API 505 is a different or another field of research.
    Occasionally hard to satisfy NFPA because of standard business operation rules and / or a standard statement at their site sets the threshold higher than I can hope to obtain when using a research technique I would hope to crack. Primarily to obtain a document that may be available by filling out a form needs to include two active members on the committee signatory approval before the form is reviewed for context. At least that is a method and considerably a lot longer process.
  4. #44
    Join Date
    Jun 2004
    Posts
    91
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hazardous Classifications 49 CFR 192.619
    Continuation of above. If one was to google above CFR one would get listings from Federal Transportation Board and Cornell University Law.
    There you would be able to surmise the transportation aspects of federal regulations for delivery of gas via pipeline and also find links to the federal register proposed Interim Agreements for looking over and / or commenting on industry documents under MAOP jurisdictions.
    It appears only to this simple transparent minded process other integral aspects to governing public safety that other organizations would adopt methods easier to understand.
    More is required for actually operating a pipeline and MAOP rule making based on transportation of hazardous gas also requires more than a few material balance flow sheets.This is where FERC process takes over plot plans and clustering of buildings and/or classification of boundaries from public buildings separation.
    So in essence it is a "..collaborative..."( as previously) by others mentioned in decision process for both changes and "...who should be recognized..." as the reviewer of Electrical Hazardous Location documents and drawings.
  5. #45
    Join Date
    Jul 2017
    Alberta, Canada
    Posts
    46
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MrJLH View Post
    Yep that was the point I'm curious about what everyone on the forum thought. Yeah I can draw out a plant and put a bubble around the equipment, but it is the process engineering who have the technical knowledge and expertise of what goes on with the units.
    I think everyone available should be consulted, including process.
    Most of the newer standards concur - they're now calling risk analysis a multidisciplinary activity, which makes sense:
    "4.4 Competence of Personnel
    The area classification should be carried out by those who understand the relevance and
    significance of the properties of the flammable substances, principles of gas/vapour
    dispersion and those who are familiar with the process and the equipment. It may be
    beneficial for other engineering disciplines, e.g. electrical and mechanical engineers, and
    personnel with specific responsibility for safety to be part of and have an input to the area
    classification process.
    The competency of the person shall be relevant to the nature of the
    plant and methodology used for carrying out the area classification. Appropriate continuing
    education or training should be undertaken by personnel on a regular basis where required."
    [Yes, OK, that's an IEC standard. All's fair in war and area classification!]
    If they're not available - well, you do your best. It may end up being a bit conservative, but c'est la vie.
    If it gets to the point where you're no longer confident you have a defensible analysis, then you have to pull in the process guys/gals, or whoever else is needed to make it work.
    However, I also agree with Bob - it's not rocket science. The methodologies are well documented.
    Just my $0.0154195 $USD.
  6. #46
    Join Date
    Jun 2018
    Atlanta, GA
    Posts
    8
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Curious on opinions of of what area classification drawings should be called for a petrochemical facility :
    Hazardous Area Classification Drawings
    or
    Electrical Area Classification Drawings
    or other titles.
    Curious on other opinions on who should determine the extent of the hazardous area(s).
    Electrical Engineer
    or
    Area Process Engineer
    Thanks
    I prefer Hazardous Area Classification, then Plan at Grade, Plan at T.O.S. Elev. X’-Y”, Elevation Looking South, etc.
    It is the hazardous area that makes it electrically classified. Hazardous Area is more intuitive to someone who is not familiar with the terminology. It tells them, “hey, this area can be dangerous”.
    I work for a medium sized EPC Engineering firm, and it is always an Instrument or Electrical engineer that develops the area classification. With that said, the electrical engineer must be familiar with the process, and the potential leak sources, so they must work with Process engineers and Pipers in the development of the HAC.
    Respectfully,
    Christopher D. Staker, PE
    Atlanta, GA
  7. #47
    Join Date
    Sep 2014
    Cincinnati, OH
    Posts
    21
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Didn't read the whole thread but this is a common issue we have at our office. Project Manager or Project Engineer points to electrical to develop the Area Class plans without input from Process engineers. Our stance, as an electrical group, is that the electrical engineers/designers develop the area class drawings based off a Hazardous Area Classification report produced by the Process Engineers.
  8. #48
    Join Date
    Jun 2013
    Florida
    Posts
    12
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I work in water and wastewater as well. I am constantly surprised with the lack of awareness of and understanding of area classification. Many of the process engineers and equipment suppliers I work with regularly have zero knowledge of the applicable codes and requirements. I usually classify areas on electrical plans because nobody else will tackle it.
    Really it's an overall lack of knowledge of building codes and NFPA codes altogether throughout the industry. I used to work on architectural projects and code knowledge was required. In this industry, it's an exception instead of the rule. Just last week I was explaining the difference between 250.66 and 250.122 to a PE with 25 years of experience in water and wastewater.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
