User Tag List
Results 1 to 7 of 7
Thread: LED retrofit pricing
  1. #1
    Join Date
    Jul 2008
    Long Island, NY
    Posts
    247
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If this has been asked and you can point me in the right direction please do, thanks. I’m trying to price up some LED retorfits for a customer. This particular job is around 700 fixtures. The bulk of it is 3 and 4 lamp T-8 lay-ins in a Office area. There’s around 150 8’ 2 lamp T-12 in the warehouse. My questions are : how many hours per fixture? We’re assuming the 4’ T-8s will get the LED lamps and ballast will need to be bypassed. The warehouse I’m not sure I can even get 8’ LED lamps and that might just need to be fixture swaps, unless you guys can recommend better product? Thanks everyone!
    Work Safer = Live Longer
  2. #2
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,723
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I would price it at 15 minutes per fixture, and yes, they do make 8' LED tubes.
    Definitely go with the type that don't keep the ballast energized.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #3
    Join Date
    Jul 2008
    Long Island, NY
    Posts
    247
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks, I was thinking somewhere in that range. Just with this being what I consider a larger job, 3 compared with 4 fixtures per hour is a big difference
  4. #4
    Join Date
    Mar 2003
    New York
    Posts
    1,940
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Can you stand on the desks?
    What voltage 277v?
    Remove old ballast?
    Store old/new lamps, vacuum, between shifts?
    Overtime or shift pay?
  5. #5
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    10,115
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by LarryFine View Post
    That's quite optimistic.
    Things I've come up against-
    Age of fixtures, condition of the tombstones
    What to do about staging and clean up
    Disposal of the fluorescent tubes
    If you don't think too good, don't think too much.
  6. #6
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by sameguy View Post
    What voltage 277v?
    Remove old ballast?
    In addition to these questions, are you having to package and/or dispose of the old lamps? how many busted tombstones do you think you're going to come across in 700 fixtures? How many emergency lights would also need battery pack replacement? Are you going to have your own lift? How much is working around employees and normal operations is going to slow you down?
    15 minutes per fixture seems a little ambitious to me.
    Eta: actiondave beat me to most of my points.
    Seta: you do realize that even if you average 18 minutes per fixture, that's 2,100 extra minutes or 35 hours of labor. I'd rather bid this high and lose it than bid it low and lose my behind..
  7. #7
    Join Date
    Oct 2011
    San Francisco, CA
    Posts
    48
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    We have found that it's usually faster and close enough in cost to just swap out the old fixtures for new LED fixtures, especially with the 2x4 lay in fixtures in the office. A lot of good examples and things to think of have already been brought up. I think 15mins a fixture is pretty aggressive given the occupied office environment. The warehouse fixtures should take more than 15 mins each since they are most likely high up and not a normal 9-10 aff.
    Not sure about New York but here in CA we have energy codes that require complete lighting system change when retrofitting or replacing a certain amount of fixtures.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
