User Tag List
Results 1 to 3 of 3
Thread: Running NM cable between door head jamb and top header?
  1. #1
    Join Date
    May 2012
    United States
    Posts
    94
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm looking at a really easy run for some NM cable, but it is between the head jamb of a door and the top header. All other paths are much harder. Thickest part of the jam is over 1 1/4 inches and there's another inch of air space before the top header.
    It seems to meet the NEC requirements for NM cable, but somehow it makes me uncomfortable. Is running nm cable here OK? If it were to be protected, how?
    There are plastic boxes on either side of the run, which makes armored cable a bit more awkward.
    Name:  door jamb nm electrical wiring.jpg
  2. #2
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So long as the cable isn't running through space where the door opens, you are fine.
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,315
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Not an issue if you 1.25" back from the edge as required. Even AC cable will be no match for the carpenters nail gun.
    Rob
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
