User Tag List
Results 1 to 8 of 8
Thread: Use of general lighting fixtures as emergency lights
  1. #1
    Join Date
    Jun 2015
    NYC, NY
    Posts
    251
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm looking for opinions how you decide which and how much lighting fixtures from general lighting must be used as emergency. assuming you know lumen output of thr fixtures, but you can't use software to calculate candles on a floor. what is rule of thumb?
    Sent from my ONEPLUS A6013 using Tapatalk
  2. #2
    Join Date
    Dec 2010
    Posts
    1,496
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you can't calculate it, then you could only verify by measurements in the field.
    The more they overthink the plumbing, the easier it is to stop up the drain
  3. #3
    Join Date
    Dec 2011
    Ocala, Florida, USA
    Posts
    3,090
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by victor.cherkashi View Post
    Why can't you use software to determine footcandle levels at the floor level?
    I know what I don't know, and I know where to go to find it!
  4. #4
    Join Date
    Jun 2015
    NYC, NY
    Posts
    251
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    by saying I can't calculate I meant I don't have photometric file to use software. I only have specification of lighting fixture with photometric chart. it's 14 watts LED. how can I estimate required distance between two emergency fixtures? rule of thumb...
  5. #5
    Join Date
    Dec 2011
    Ocala, Florida, USA
    Posts
    3,090
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Because I have too much trouble reading the charts, I would cheat and just call the distributor who represents that fixture and ask him. He likely has the software.
  6. #6
    Join Date
    Mar 2003
    New York
    Posts
    1,907
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Like above supply house/manufacturers or the fixture has beam spread over height. So overlap your foot candela and read the center to center measurements.
  7. #7
    Join Date
    Oct 2010
    Posts
    22
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    lumen output of the fixture in an IES file will not be accurate for calculating FC levels in an emergency situation. EMG batteries have a specific lumen output which will be lower than the lumen output of the fixture during regular use.
    you can talk to the emergency battery mfg to obtain this.
  8. #8
    Join Date
    Dec 2010
    Posts
    1,496
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by thewiseguy31 View Post
    OP didn't mention batteries.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
