User Tag List
Results 1 to 10 of 10
Thread: Soft-start LED's
  1. #1
    Join Date
    May 2010
    Inside the Beltway
    Posts
    646
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Soft-start LED's
    Are there any outdoor floodlight fixtures with soft-start LED's?
    I have a case where the homeowner hates motion-tripped illumination as it startles her, but she needs it.
    I was hoping she might be OK with a slower starting lamp.
  2. #2
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,734
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Possible alternate: Dual-brite lights that dim instead of extinguishing after timing out.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #3
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,619
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    181205-2422 EST
    Open Neutral:
    Why would you expect one to exist? It would add cost.
    A basic LED chip is essentially a very fast response device. Picoseconds or higher. With added phosphors to make white light it is somewhat slower. To get some sort of ramping slow light buildup you will require additional circuitry. Are there slow ramping dimmers? I don't know. Quite possibly some home automation system might have such a feature.
  4. #4
    Join Date
    May 2010
    Inside the Beltway
    Posts
    646
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gar View Post
    181205-2422 EST
    Open Neutral:
    https://www.maximintegrated.com/en/a...ex.mvp/id/4481
  5. #5
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    10,737
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Any way you can combine them with a dimmer that slowly goes full bright? I noticed a Lutron dimmer worked that way last week.
    Tom
    TBLO
  6. #6
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,619
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    181206-0947 EST
    Open Neutral:
    Interesting. I like Dallas, now Maxim. If one already uses the Maxim chip, then it won't be a huge cost factor.
  7. #7
    Join Date
    May 2010
    Inside the Beltway
    Posts
    646
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ptonsparky View Post
    Would love to see same. Don't want to engineer my own.
  8. #8
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Open Neutral View Post
    Another possible alternative: using multiple fixtures with lower intensity LEDs... Or having the ability to turn them on remotely, thus avoiding the shock of going from full darkness to gas station bright (lower Kelvin lamps would also help in that regard).
  9. #9
    Join Date
    May 2010
    Inside the Beltway
    Posts
    646
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The point is to stop running the driveway lighting several thousand hours per year, and instead automagically turn them on when there's a reason to do so.
  10. #10
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    40,150
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Still have recessed halogen flood bulbs around my house, but for similar reasons. They come on every night with a photocell, but are on dimmer switches and set to low light level. Makes good security lighting. Now if I want more light temporarily I could turn up the dimmers. I don't have but if I wanted I could probably bypass the dimmers with a motion detector if I wanted automatic light increase, or even turn on additional luminaires with the motion detector.
    Did about same thing on a newer house I wired but have dimmable LED trims in the cans.
    I live for today, I'm just a day behind.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
