User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: GFCI quiz
  1. #11
    Join Date
    Sep 2016
    Atlanta, GA
    Posts
    147
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gar View Post
    181207-2111 EST
    A separate question is if a capacitor is connected between hot and neutral on the output side of a GFCI does the GFCI current transformer balance the two currents, in and out, to prevent tripping. I would hope so, haven't run the experiment.
    Some specific controlled experiments are needed.
    It's supposed to be raining here tomorrow. Ill see if i can't run that "controlled experiment" in the afternoon
    Sent from my SM-G950U using Tapatalk
  2. #12
    Join Date
    Jul 2013
    Renton, WA
    Posts
    955
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    controlled experiment...
    When a 10 YO kid, knew if we tried to play the record player while sitting on the well grounded air duct to the gravity coal furnace, if we would get a good shock picking up the metal tone arm, we knew to reverse the plug.
    Years later, looked inside that cheap little tube (all American 5 set of tubes) radio/phonograph and there was a 0.1 uF cap to chassis from one side of the line cord, if no cap - LOTS of hum on the phonograph. Also 4+ mA 60 Hz leakage with the cap.
    The EMI filter on my 120 Vac input, 120Adc 14 Vdc output battery charger uses a SMPS to keep the weight down, the EMI filter has 0.2 uF caps to chassis and green wire. Cannot use on GFCI circuit.
  3. #13
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    1,073
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoldDigger View Post
    Many old phonographs and radios connected one side of the AC line to the metal chassis ...
    Quote Originally Posted by LarryFine View Post
    They were also among the first electrical devices to come with polarized plugs ...
    Installing a polarized plug will sometimes improve matters. If the device is old enough to contain vacuum tubes, it's probably time to replace the entire cord. Cleaning it and installing new non-conductive feet, and/or a non-conductive false bottom, might also help.
    I once had an old favorite 6-tube AM radio, probably built c.1960. Hot chassis, no power transformer, plastic case, chassis mounted to the case by sheet-metal screws through the bottom.
    It was on a freestanding steel shelf in an unfinished basement, and initially unknown to me, sitting on a small piece of metal junk. It made contact between the shelf and one of those sheet-metal screws, and energized the entire shelf. (no GFCIs at the time) Nobody got shocked because the basement walls leaked. It rained, there was water on the floor, and the points where the shelf legs contacted the wet concrete were steaming.
  4. #14
    Join Date
    May 2007
    Posts
    957
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Older Phonograph shock experiment
    This thread takes me back to the 60's and a portable phonograph experience I have never forgot.
    As others have said the chassis could become hot if the plug was not polarized.
    I had bought my first electric guitar ( I was going to be a Beatle!) I could not afford the amplifier so I added a guitar jack to a portable phonograph to use its amp.
    I came home wet after a storm and started to play. Touching both the guitar strings and the chassis I got lit up.
    I was shocked to discover I did not have any talent as a musician
    I think that the leakage standards- to ground, have changed as the years progressed and thus older EMI filtering utilized larger caps than what would be allowed today.
    I recall experiencing several pieces of equipment that would trip GFIs when GFIs were still new.
    - Resistance is Futile ..... (if less than < 1 ohm) -
  5. #15
    Join Date
    Feb 2016
    Illinois
    Posts
    1,345
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ELA View Post
    Nice pun!
  6. #16
    Join Date
    Jun 2007
    Fredericksburg, VA 21 Hours from Winged Horses with traffic
    Posts
    242
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My GFCI trips because of Blue Tailed Skinks. [ https://www.virginiaherpetologicalso...f_virginia.htm ]
    They squeeze into the outside receptacle boxes through the mortar lines in the bricks on one particular receptacle. They seem to live through the experience.
    I was working on a Westinghouse TV years ago, swung the "rabbit ears" around and they struck the water pipe above the workbench. Sparks flew, WTF? It has a polarized cord, and I knew my receptacle was wired right. Sure enough, the factory wired the "cheater cord socket" so the chassis was always hot, i.e. narrow blade of the power cord was connected to chassis. Set had been in service more than 10 years at that point, guess no owners got shocked along the way. I corrected the error and returned the set working.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
